Mach3 controls the printer port at a system level, this is necessary to give precise timing. Mach3 will need to know the address of the printer port and getting this will vary slightly according to the flavour of Windows you use. Then you have to put that info into Mach3 - if you have any difficulty with this then I can switch on my XP machine which is my CNC computer and remind myself how exactly. All my other computers use Wifi network printers (actually only one at the moment).
After you have configured Mach3 to use the printer port, then all the other configuration apart from the steps per, acceleration and speeds are in the document I sent you.
Cheers,
Rob
18-12-2019 #2
Thanks Cropwell. You mention the printer port. Are you suggesting I use that one instead of the pci card parallel port? I must admit, when I was playing around with it last time, and I was trying to set all the keys, it was pinging the machine more successfully through the main parallel port than it was the one on the card. Either way, I will hopefully have a go at it this weekend and let you all know how its going.
RC cars
RC helicopters
Motorbikes
Renovating an entire house
Twatter: @CrazyLThirteen
Insta: CrazyLThirteen
CNC problems
By martythunder in forum General DiscussionReplies: 1Last Post: 15-02-2017, 08:10 PM -
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
