    Hi all i started this spring, with building my own CNC router. Gantry is cut out off 25 mm aluminium, bought at the local scrapyard, Dry cut on my table saw with a woodcutting blade. Sometimes it was one step ahead 3 step backwards. But slowly i am getting to the end off the project, I started with a ordinary grinder - but YIKE dust everywhere, So atm i am rebuilding with a spindle motor -VFD - and trying to make a dust collecting system. Yike i couden't find out how to place pictures in this topic - so i put them in the photo album : Photo album is deleted and pictures is moved to this thread
    Welcome to the forum JanBo.
    It looks like an interesting build from your photos http://www.mycncuk.com/album.php?alb...chmentid=26582 and obviously successful in that you are actually cutting things!
    Unfortunately browsing through your album is spoiled by the way the software displays them on my PC with a stripe of "trending . . ." through the middle. Screenshot for Lee:
Name:	2019-10-19 17_16_19-Photo 3 of 27 from CNC build.png
    Quote Originally Posted by AndyGuid View Post
    Noted thank you.
  4. The Following User Says Thank You to Lee Roberts For This Useful Post:
  5. #4
    Hi Andy.
    Aparently i got the same issue with the pics, i will try to solve it or try to get them to this thread.
    Jan
  6. #5
ID:	26591Click image for larger version.
ID:	26592Click image for larger version.
ID:	26593Click image for larger version.
ID:	26594Click image for larger version.
    1'st picture is the stuff i bought from a scratched CNC router.
    Picture 2 to 5 is dry cutting a 25 mm alu plate on my table saw
  7. #6
ID:	26619Click image for larger version.
ID:	26620Click image for larger version.
ID:	26621Click image for larger version.
    Found something usefull at the local scrap dealer - and my workplace got a new welding table - so i managed to get the old welding plate for free - ended up with a under table 1,5 X 1,0 meters
  8. #7
ID:	26623Click image for larger version.
ID:	26624Click image for larger version.
ID:	26625Click image for larger version.
ID:	26626Click image for larger version.
    Work on mounthing stuff
  9. #8
ID:	26628Click image for larger version.
ID:	26629Click image for larger version.
    Mounted it with a router - but YIKE quiet a problem - dust everywhere when cutting
  10. #9
ID:	26631Click image for larger version.
    Attempts to use the CNC router - and the newest work on the machine - switching to a spindle and a frequency converter - and trying to make a dust colllecting system - at a standstill atm waiting for the frequency converter to arrive
  11. #10
    [Click image for larger version.
ID:	26617Click image for larger version.
    Gantry build
  1. BUILD LOG: jon's homemade cnc
    By jonbabbz in forum DIY Router Build Logs
    Last Post: 11-03-2021, 05:13 AM
  2. Can anyone recomend a firm that buid small high spec routers?
    By suesi34e in forum General Discussion
    Last Post: 27-10-2015, 08:14 PM
  3. Homemade CNC Project Help
    By chaslam07 in forum Gantry/Router Machines & Building
    Last Post: 04-04-2012, 11:53 AM
  4. BUILD LOG: Few pics of my homemade CNC mill
    By wiatroda in forum DIY Router Build Logs
    Last Post: 18-02-2011, 09:43 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
