    The S/H CNC turret machine I was looking at I was told 'has ballscrews on all axis that are driven by DC servo motors.'
    Also, 'the control is very easy to program you can also run it with a cad cam program or the offline software.'
    Sounds OK does it not for working with Fusion 360 but the Anilam 3300 control panel DRO has an old cathode screen would it be easy to replace?
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 8-9 years. Has a total post count of 475. Received thanks 104 times, giving thanks to others 43 times. Referred 1 members to the community.
    Very generally speaking, all CNC machines should use GCode - which are literal instructions to the machine about where to move in sequence, for example:
    Move quickly to X=10, Y=0, Z=10
    Turn on the spindle
    Move at this feed rate to Z = 0
    This is the set of instructions which the CAM program makes. The controller on the CNC is responsible for enacting those instructions precisely.
    If you buy a used CNC, it should be able to take these instructions from any CAD program. It may also have some manual offline functions as you mentioned, but they will be machine specific.
    Now, replacing the cathode screen. This is likely to be a can of worms; it probably won't be just a standard interface to swap out (it might be, but certainly don't bank on it). Often, if there is any problems with the machine controller it's worth considering ripping it out and rewiring the entire thing with a more modern controller - but this gets very complex and expensive very quickly.
    Quote Originally Posted by Faszero View Post
    Unfortunately, It's a little more complex than just selecting a Cam program.
    First, the Cam software you use must have a post-processor that suits the controller your using and doubt Vectric or F360 will have a Post for these old Anilim controllers as often they are programmed at the controller or by hand and imported which leads to next issue..
    Second, these Old Controllers are often limited on memory and modern Cam programs writers are lazy so they spit out large file sizes for even the simplist tool-paths. This means you have to drip feed them code and this leads to all sorts of issues with drop outs etc.
    Third, retrofitting isn't a simple affair either. DC Servo drives on these older machines nearly always require Analog signals so require an expensive analog controller.
    The DC Motors can be re-used with modern DC drives but even this isn't a simple switch as they tend to use Single-ended encoders and/or tacho's which need to be replaced or bypassed with modern differential encoders which modern drives will require.
    All these things become expensive really quickly and are why often they get ripped out and replaced with modern controllers and motors/drives etc
    That said if the machine really does have ballscrews fitted already then it's a good head start as often fitting ball-screws isn't a cheap or simple swap and requires a lot of work in many cases.
  1. Help me choose my first spindle
    By Desertboy in forum Spindles & Drive Motors
    Last Post: 04-05-2018, 10:49 AM
  2. Replies: 0
  3. Help needed to choose a machine.
    By DustySixString in forum Machine Discussion
    Last Post: 28-07-2017, 04:47 PM
  4. HELP:How to choose
    By sinograver in forum Milling Machines, Builds & Conversions
    Last Post: 17-10-2011, 02:00 AM
