Thread: Milling/Drilling Head
01-11-2019 #1
Wanted a small milling head for a little mill. Say 3/4 to 1 hp, If you have perhaps a broken base or table, I would be pleased to purchase your head unit. - Could take a bench drill head if available. Anything considered.
03-11-2019 #2
Warco do a column and head that is designed to fit on the bed of a lathe if that is of any help.
https://www.warco.co.uk/milling-mach...n-machine.html
Or
04-11-2019 #3
I should perhaps confess, that this is very much a sit in the corner project that is not absolutely required. It is a guilt thing because it has been sitting there for years. As such, from time to time I look up and try to find something that could be cobbled on to it. Expensive options, are really not an option. Simply looking for a lucky cheapskate option. Those that have such "artefacts" may understand?
It is by the way a Swiss Micron and too good to discard or completely dismiss. Even fitted with X,Y,Z DRO`s
4Axis 0.8KW Router Engraving Machine Milling Drilling Engravor 3040 CNC Machine
By KeithElcomb in forum Chinese MachinesReplies: 0Last Post: 27-09-2017, 12:32 PM -
Emco Unimat Milling Head Conversion
By magicniner in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-07-2016, 09:04 PM -
Lenzkes Tooling Clamps Qty2 - CNC Milling/Drilling
By mekanik in forum Workshop & EquipmentReplies: 2Last Post: 02-02-2015, 06:47 PM -
WANTED: Small milling head
By johnsattuk in forum Items WantedReplies: 0Last Post: 14-03-2014, 08:54 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM
