Thread: Hard Turning a Clean Sharp Edge
I suppose the answer would vary depending on how many thousands of blades you are producing. My approach would be to turn as fine an edge as you can without causing deformation and then refine the edge faces with an abrasive stone attached to a shank. There again, I tend to look for the QAN solution.
Hard (Turning)Times
By magicniner in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 16-10-2018, 02:30 PM -
Turning hard materials
By Harry Hills in forum Metalwork DiscussionReplies: 16Last Post: 07-02-2016, 04:49 PM -
Cutting sharp square internal corners , newbie
By CommanderKenyon in forum Tool & Tooling TechnologyReplies: 4Last Post: 02-11-2015, 02:14 PM -
Keeping hywin rails clean?
By charlieuk in forum General DiscussionReplies: 11Last Post: 01-01-2015, 03:12 PM -
NEW MEMBER: At the sharp end
By chancersw in forum New Member IntroductionsReplies: 3Last Post: 18-08-2009, 12:39 AM
