09-11-2019 #2
With the right spindle on my machine it probably would, but the reason I went with that overall layout was I wanted a large cutting area for sheets of wood, but still be able to mill with it.
If you don't need anything that large then a either a regular mill style (column at the rear XY table in front), or a fixed gantry with moving table would be better.
Either way you would need a spindle with high torque and low rpm, in the hundreds of rpm for the annular drilling.
How to drill gems?
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 13Last Post: 03-04-2016, 11:10 AM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
Stumpy 3.5mm drill bit?
By craigrobbo in forum Tool & Tooling TechnologyReplies: 8Last Post: 09-04-2013, 01:33 AM -
drill size
By luke11cnc in forum Tool & Tooling TechnologyReplies: 3Last Post: 09-08-2011, 12:25 PM
