11-11-2019 #12
A large thick-walled aluminium box section can have considerable rigidity and weight-for weight won't be a long way off steel, however it won't have the torsional rigidity to cope with the sort of drilling you want to do, leastways not with a 1.3...1.4m long gantry. I'm only thinking of making something that will drill (sometimes) & tap (quite a lot) up to 8 or 10mm in aluminium or maybe 5...6mm in steel, larger holes would be milled out.
Stepper motors are nearly always listed by their size and torque (e.g. Nema34 8.5Nm), ball screws have their maximum static and dynamic axial load ratings listed in the data sheet by Coa and Ca, it's worth checking these as it would seem they can vary between manufacturers for a given size.Last edited by Voicecoil; 12-11-2019 at 11:14 AM.
The Following User Says Thank You to Voicecoil For This Useful Post:
How to drill gems?
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 13Last Post: 03-04-2016, 11:10 AM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
Stumpy 3.5mm drill bit?
By craigrobbo in forum Tool & Tooling TechnologyReplies: 8Last Post: 09-04-2013, 01:33 AM -
drill size
By luke11cnc in forum Tool & Tooling TechnologyReplies: 3Last Post: 09-08-2011, 12:25 PM
