    Mud's Avatar
    Lives in Bristol, United Kingdom. Last Activity: 11-12-2020 Has been a member for 6-7 years. Has a total post count of 23. Received thanks 3 times, giving thanks to others 0 times.
    Hi all, I have a Wadkin TC80 spindle intended for my next machine build, and beyond a marketing pamphlet I have no real information, i.e.:
    *air-cooled
    *7.5kW
    *0-20,000rpm
    *30 taper
    *hydraulic tool release
    Additional info I have ascertained:
    *green
    *heavy
    I believe the machine it came off of was an Olympus.
    It has a threaded hole in the front that did not have a fitting or bolt in (just taped over) which has me wondering if it's meant to have a continuous lube feed or forced air cooling. This was the standard spindle Wadkin offered at that time and not a fancier higher load/higher precision option. The spindle seems in good condition, so I don't really want to take it apart! Maintenance requirements would be great to know. Any ideas?
    https://www.daltonswadkin.com/wp-con...0M-CONTROL.pdf
    Mentions your head being cooled by an electric fan, I didn't read past that.
    Mud's Avatar
    That's ace - hadn't found that doc. I'll settle in and read it properly (especially since it isn't searchable), but I see on p24 it says the TC (100, not 80) is greased for life, and doesn't mention an air supply for cooling like the LC head :)
    e: ah, p30, the motor is cooled by an electric fan. I have the motor, and it's an utter monster. Not going to be used on this particular machine!
    Weak your Google-Fu is Grasshopper, work on that you must! ;-)
    Mud's Avatar
    I was even on that site, not sure where I failed!
    Mud's Avatar
    Hmm, p94, 'compressor to give .56m^3 (5.3 cubic feet) of free air per minute at 5.3 bar. They've messed up the calc though, .56m^3 is 19.8 cubic feet. I guess it would be the higher throughput based on the similar power spindle options, might be time for a bigger compressor =/
    Mud's Avatar
    I think the open port is an air input - blowing into it I found what appears to be a single vent (open hole with no features - circled red in picture). I've fitted an 1/8" BSP air fitting.
ID:	26738Click image for larger version.
  1. Replies: 0
    Last Post: 14-01-2019, 06:29 PM
  2. NEW MEMBER: New member seeking advice from those in the know
    By jonny5 in forum New Member Introductions
    Last Post: 04-02-2017, 06:58 AM
  3. FOR SALE: Wadkin cc2000s router for sale
    By CNC Graham in forum Items For Sale
    Last Post: 18-01-2016, 10:55 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. wadkin ux2lc/c3 with bosh cc100 controller
    By george uk in forum Machine Discussion
    Last Post: 31-01-2014, 03:25 PM
