11-11-2019 #6
Couple of things to add if you are starting out:
Label the UVW cables once the direction is established as correct so you don’t have to play lucky dip should you disconnect it in future.
Ensure all joints between the VFD and the motor are tight, and any plug sockets remain tight without any strain or opportunity to fatigue over time. If the motor is running and there is any interruption in the UVW cables power supply the VFD will most likely be damaged.
Huanyang HY01D523B inverter settings.
By JimK in forum Motor Drivers & ControllersReplies: 1Last Post: 18-08-2019, 04:15 PM -
Huanyang VFD and spindle problem
By BriceO in forum Spindles & Drive MotorsReplies: 20Last Post: 07-08-2018, 08:56 AM -
Wiring Huanyang HY02D223B
By Stan in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2017, 07:25 AM -
50/60 volt spindle inverter.
By GEOFFREY in forum Spindles & Drive MotorsReplies: 0Last Post: 24-12-2012, 03:58 PM -
Wiring a Teco inverter
By Robin Hewitt in forum General ElectronicsReplies: 9Last Post: 04-04-2009, 09:12 PM
