23-11-2019 #14
I think the main point of this work is that the DESIGN is bespoke and made to suit non-standard customers. The labour-intensive manufacturing process is then something that merely increases the cost and reduces the accessibility.
I do like the multiple small machines idea. This will be the least expensive for a given quality of result and allows for expansion as cropwell suggests. It would also allow for reduced set-up time and tool or jig changing if, for example, all the hinge pockets were the same, all the frame blanks would mount up in the same way before bespoke machining. You could build up to having a row of machines each doing one task on a production line basis and concentrate the hand finishing work where it's really needed.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Bespoke Drinks Coasters
By Wal in forum Woodworking Project ShowcaseReplies: 25Last Post: 01-07-2019, 02:27 PM -
NEW MEMBER: Instrument maker
By Grambot in forum New Member IntroductionsReplies: 35Last Post: 24-10-2016, 12:28 PM -
pulling my hair out with cam
By universally in forum CAD & CAM SoftwareReplies: 6Last Post: 09-04-2015, 01:41 PM -
Bespoke CNC
By Prop Man in forum General DiscussionReplies: 18Last Post: 13-12-2010, 05:17 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM
