The other thing to think about is how you will align the tool height to the spindle centre. If you are going very simple then the surface the tool sits on needs to be on the low side so you can shim up to suit each tool. You can't shim down.
More complex arrangements are a quick change tool holder with a threaded height adjuster per tool. I would have a look at this option as it makes tool changes quick without dialing them in each time or keeping a set of shims per tool.
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
Large Format Epoxy Granite Gantry CNC - Looking For Feedback
By Max Maker in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2019, 04:57 PM -
SOLD: Hobbymat MD65 mini lathe and BF65 mini mill
By Boyan Silyavski in forum Items For SaleReplies: 3Last Post: 03-11-2018, 12:45 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM
