Thread: theoretical speed
22-11-2019 #1
hi all I am running 1610 ballscrews on my y axis with 3nm nema 23 motors and no gearing, and twin 1610 screws on my x axis with a single 8nm nema 34. my drivers are em806 drivers with a 68v power supply. all axis are on hiwin 20mm rails. roughly what rapid speeds should I be able to achieve with this setup not taking in to account weight of axis etc. thanks all
23-11-2019 #2
Go to this page:
https://www.zappautomation.co.uk/ecalculators.html
Click on 'Critical Speed Calculator' in blue at the bottom.
That tells you how fast the screws can go before whipping. You didn't say how long they are so or how they're supported so I can't go and find that for you :P
Thats the big limit on maximum rapid speed - what is of more interest is if you can accelerate up to a max rapid speed in a reasonable distance, but thats a far more complex question. On this forum is a motor calculation spreadsheet which will answer your question, but you'll need to provide it with a lot more information. Look at the thread below for the spreadsheet and discussion on how to use it. Page 3 of my build log details the calculations for my build which sounds similar to your setup.
http://www.mycncuk.com/threads/1524-...otor-do-I-need
Now, having said all that, assuming a typical design and weight of gantry ~50kg, you should be able to reach 5m/min rapids without any issues.
Speed limits...
By Davek0974 in forum Bridgeport Milling MachinesReplies: 2Last Post: 30-01-2018, 10:20 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
Adjusting speed with vfd
By motoxy in forum Spindles & Drive MotorsReplies: 8Last Post: 24-09-2012, 04:07 PM -
Top speed failing after a bit
By Robin Hewitt in forum Machine DiscussionReplies: 6Last Post: 12-11-2011, 12:46 PM
