16-06-2020 #10
Question for Doddy,
I've scoped the common mode noise and it isn't sufficient to cause a phantom step to be read at the 328p. I think the phantom steps I was detecting that I have 'fixed' by debouncing the read are actually being caused by reflections and/or induced voltage spikes as the differential pair switches. If this is correct placing a termination resistor across the pair as you do for rs485 should help do you concur?
Cheers, Joe
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
