    I temporarily bolted a length of rail to the slot, it seems to mount extremely firmly and doesn't move (maybe helped by the very slight V angle it is sitting in) but must be slightly canted as discussed above. Will decide whether to face mill it tomorrow, another option is just to mill a few mm each side of the slot so the rail can sit flat, this would also preserve the 3 planar points (both corners and centre) in case I mess up.
    I initially wanted to fix the rail to the centre however this does increase the moment between the Y bearing and the Z plate by 20mm which may counter the increased stiffness from the firmer rail mounting.Then again the centre of this extrusion will be stiffer than either slot as it i supported equally whereas the slots are supported on one side by the unsupported corner. No idea really.
    In the mean time I spent at least an hour tapping the ends:
Name:	IMG_20191218_141428 (Large).jpg
ID:	26915 Click image for larger version.
Name:	IMG_20191218_141509 (Large).jpg
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
