Quote Originally Posted by devmonkey View Post
If you have access to a milling machine I would definitely put them top and bottom. If you want to mount them on the face and keep the same rail separation then you need a deeper gantry, if you use 160x80 profile for the gantry then the Y rail centres will *only* be 120mm apart (distance between outermost slots), the same profile with top-bottom mounts gets you ~180mm centres. On my last machine I used 160mm ali box section for the gantry and with face mounting close to the edges got around 140mm centres.
So do you think the difference with 40-50mm extra offset will make any notable difference to stiffness?
Skickat från min SM-A530F via Tapatalk
