08-12-2019 #21
I got mine from Simmal (you might need to email/ring them as they don't keep everything ont' website), I suspect other places like DoRé Metals & Smiths might have it too.
08-12-2019 #22
Yes probably seen gantry I've shown built from plate and few others used it or adapted to there machines. It makes for a very stiff gantry,
However, it needs a lot more work compared to HD profile. I've used all methods of constructing gantry's and HD profile is by far simpler with more than enough strength for any Router cutting materials up to Aluminium.
Aluminium Rect section doesn't compare to HD profile in terms of resonance and vibration dampening and this is should be more of a concern than twisting deflection you seem to be chasing if you want a good Router.
There is no cutter you will use that will withstand forces enough to twist a gantry made form any of these materials before it snaps. However, Resonance will affect any cutter and the smaller the cutter the worse it gets. My advice is to Stop chasing twisting etc and look more to lowering resonance if you want a good Router.
09-12-2019 #23
09-12-2019 #24
Hi Jazz,
Thanks for the advice. Do you have any pictures or wise words on how a 'stiff' gantry was made with plate? From the calculations I did a simple channel from 16mm plate is not sufficiently stiff in torsion at 1/10th that of 160x80 profile.
I'm trying to reuse a set of HGR15 rails left over from another project on the Y. These were originally purchased to replace rails on a much larger machine that had rusted badly, since then that machine has been written off.
15mm rails are too narrow to go over an 8mm slot, this means they will need to be drilled and tapped into the centre flat section between two slots or another plate milled to bridge the slots and then mounted to that. If the latter then it isn't much more work to mill up a front plate as well.
If I already had 20mm rails for Y then the profile would be a no brainer as the rails could be bolted straight into the slot.Last edited by devmonkey; 09-12-2019 at 10:20 AM.
10-12-2019 #25
Right I've made a decision!
I called around a load of my usual aluminium guys, Smiths, Aalco, Blackburns, plus a couple of local metal shops. No one has any 6x3x3/8 box on the shelf (even Aalco who have a warehouse near me about 10 acres in size) and although they could get it I would need to buy a full length. To be fair I didn't try Simmal.
I've built two previous machines using 6x2x1/4 box and they worked fine albeit I had to shim the rails, only very slightly as I didn't have a mill back then and I had to bolt blocks into the ends to bolt into (not required on the 3/8 box). Anyway I'm just going to go with the original plan from the first post in this thread, will order some 160x80 Item heavy clone from KJN tomorrow.
I will first try to just mount rails directly to the central flat on the profile, if this turns out too wobbly I will plate over the slots and fix rails to plate.
13-12-2019 #26
14-12-2019 #27
Finished the Z back plate so have now assembled the Z. Everything fits perfectly. All 4 long edges of the large front and back plates were milled in a single fixture so these will all be reference edges for aligning the rails and also tramming the Z on the gantry.
Pockets for the ballscrew mounts, these weren't perfect were supposed to be 1mm deep, infact 1.28mm so will need a thin shim between front plate and ball nut holder. TBH ballnut holder is not a precision item, rather it is a cast lump, so probably would have needed shimming anyway.
I'm now waiting on the extrusion to arrive for the gantry as I need this to measure off for the Y bearing plates, gantry end plates, etc. Hopefully should be here early next week.Last edited by devmonkey; 14-12-2019 at 05:27 PM.
14-12-2019 #28
How do I make the images in these posts larger rather than just thumbnails?
15-12-2019 #29
Joe,
That's looking very impressive.
Clicking on the thumbnails takes you to the larger versions which, on my laptop at least, are sized to fit the screen. Clicking again will enlarge them to what looks to me to be 'actual pixels' size.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
15-12-2019 #30
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
