16-08-2020 #201
Very nice gentlemen....I want to be able to do that when I grow up.
16-08-2020 #202
16-08-2020 #203
Very nice Kit! This was the first time I'd used trochoidal clearing, definitely a keeper for thin endmills in metal.
Now I have a question for you pulley experts. I need to make a very large 157 tooth 8m timing pulley ring that will be fitted to the perimeter of a winch drum. The pulley needs to be made of a ring of material ~25mm thick with an outer diameter of 400mm and inner of 340mm. It could be made from aluminium, SRBP, delrin or even hdpe.
Trouble is I don't want to waste a large piece of material just to make the ring, any ideas? I've even considered casting a blank in aluminium but I don't have a foundry. Are there any castable machineable urethanes that are strong enough for timing belt pulley teeth?
16-08-2020 #204
I'm well pleased with the trocho pocket plug-in, it's a major step forward in being able to make hardwood clock wheels sucessfully.
How are you designing the ring of teeth for the pulley? I have the Gearotic software which can create accurate timing pulleys in all sorts of formats. If you need help with that I can send you a PDF for importing into CamBam (that's another plug-in).
Well if you want to get into a new hobby that involves playing with fire, melting aluminium is easy. The YT video below gives you the idea. Use previously cast aluminium alloys (old water pumps from your friendly neighbourhood motor mender etc.) rather than cans or other scrap. Sawing off the bottom of an old fire extinguisher makes a good crucible. Getting a sucessful cast with it is another story however.
Not sure on the use of 2-part plastics for something this robust or how well they machine but one option to consider is to make a master in MDF with your CNC machine and then a silicone mold to cast the final pulley ring, or a blank for final machining. I've done a bit of this for arty stuff but not for engineering. You aren't going to buy from Australia but the Barnes site linked below has info on materials and how to use them. Similar stuff will be available in Pommieland.
https://www.barnes.com.au/
https://www.youtube.com/watch?v=lSoWxG30rb0
Good luck
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
16-08-2020 #205
I use a free command line dxf generator that can generate all of the main timing pulley profiles, super simple.
I just cut an 8m test pulley in 10mm SRBP P1, if came out very nice and extremely strong teeth. I think I will use this material and laminate a few layers together then bolt through, it is pretty cheap stuff and locally available to me.
16-08-2020 #206
16-08-2020 #207
Here you go, https://github.com/paulius-zubaviciu...file-generator
You need java to run it.
The Following User Says Thank You to devmonkey For This Useful Post:
26-08-2020 #208
I made the large timing pulley I was proposing today, it is a 157 tooth HTD 8M (20mm belt) for a project, pulley is ~400mm diameter. It was made from 10mm SBRP with 3 laminations at the rim. Turned out fantastic. I used screwfix cyano to laminate, this makes a very strong joint which you cannot get apart. It will never the less be reinforced with a ring of M5 bolts.
26-08-2020 #209
26-08-2020 #210
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
