    Finished the Z back plate so have now assembled the Z. Everything fits perfectly. All 4 long edges of the large front and back plates were milled in a single fixture so these will all be reference edges for aligning the rails and also tramming the Z on the gantry.
Name:	IMG_20191214_161417 (Large).jpg
    Pockets for the ballscrew mounts, these weren't perfect were supposed to be 1mm deep, infact 1.28mm so will need a thin shim between front plate and ball nut holder. TBH ballnut holder is not a precision item, rather it is a cast lump, so probably would have needed shimming anyway.
Name:	IMG_20191214_161439 (Large).jpg
Name:	IMG_20191214_160624 (Large).jpg
ID:	26872 Click image for larger version.
Name:	IMG_20191214_160503 (Large).jpg
ID:	26873 Click image for larger version.
Name:	IMG_20191214_160353 (Large).jpg
ID:	26874 Click image for larger version.
Name:	IMG_20191214_160341 (Large).jpg
    I'm now waiting on the extrusion to arrive for the gantry as I need this to measure off for the Y bearing plates, gantry end plates, etc. Hopefully should be here early next week.
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
