    Y rails are now fixed in their final position using the setting tools described above, worked very well and was super quick to do. Both gantry end assemblies are aligned and bolted to check final fit, everything looks good. Note rubber mallet, this is a precision build honest ;-)
Name:	IMG_20200102_201130 (Large).jpg
    Other than ballscrews everything from the X plates upwards is now complete, will move back to the steel frame next, need to decide whether to pour epoxy or attempt to rig up a mobile surface grinding contraption to bring the frame into plane.
    Jazz when you fettle beams holding the X rails into plane do you just scrape by hand checking with a precision level and blueing off a surface plate large enough to span the two X beams? Or do you just level each beam locally then shim one side to bring into plane? My last larger machine had X beams that could be adjusted independently up and down with the rail attached, this one has beams welded to the frame.
    Cheers, Joe
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
