07-06-2020 #11
Clock of DDCS is 500khz, my code mirrors directly off the port so low overhead compared to arduino libs. I will verify propagation delay with the scope. PC817s are only on switches not step/dir, this is also the opto inside the DDCS, i've just had a look. Agree easy to build part of it with multiplexers but I'm not sure it is required. I've got a box full of ESPs here, again not required for this.
With 16x ustepping and 10mm pitch screws you are at 320 steps/mm so 500kHz gives 1500mm/s and a screw speed of 10k rpm, we only need 1/10th of this tops so I don't think frequency will be an issue.
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
