07-06-2020 #11
Yeh the I2C is the dubious part, albeit it is done in hardware, I haven't coded that yet, if it gets in the way it can be omitted. I just usually add them to all my boards these days as I have a drawer full and they only cost a few quid. In this case I had disable the uart to use the rx/tx pins for outputs so without I2C there is no way to get any debug out whilst testing. I did this so I could get a full 8 bit synchronous port write to the drivers rather that making multiple consecutive writes. Every true IO pin is in use ;-)
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
