    You have. It's called a CNC router. The trick is making the machine and your ability to register a pre-etched circuit board on it accurate enough. Something I haven't even atempted yet.
    I do like using the solder paste. That and a gas soldering iron with a hot-air head makes hand-soldering SOIC chips nice sand easy and the 1.27mm (thats 0.05 inch for our 19th century readers) pad spacing is reliably makeable using the toner-transfer method for DIY circuit boards....without holes!!!
    Kit
    For crude through hole boards with thick traces like this one I use the toner transfer method with a £50 Brother laser printer from Argos, good results and takes <15 mins to make a board including etch and drill, I drill by hand on a tiny toy CNC machine. This process works well for double sided boards as well.
Name:	IMG_20200610_080421 (Large).jpg
    For higher resolution boards I use a CNC photo method on the same toy machine. Spray the copper with black paint then use a low power UV laser in the machine to isolation route it. Wash off the ablated paint then etch. If the board requires any drilling and/or is double sided I use a fixture so to re-locate it after etch. This process takes a bit longer but I can achieve 0.2mm features/tracks.
    Anything more complicated with >2 layers gets sent to China, even if just a proto. All the SMD stuff gets soldered with hot air, agree very easy if your solder paste isn't like gritty chewing gum.
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
