10-06-2020 #10
So I've just scoped the DDCS. An axis setup as per my machine, 1610 screw, 16x ustepping -> 320 steps/mm, max speed 10000mm/min.
As expected step frequency is ~53kHz, half period of 9.375us. Nyquist/Shannon tell us that this needs to be sampled at a minimum of 2f, i.e. 106kHz for perfect reconstruction. Puts an upper bound on my mirror code latency of ~9us, so to be safe say 5us. This is 80 cpu cycles, will it fit?? Should do, got to wire it in and test.
DDCS defaults set dir 7000ns (7us) ahead of step therefore code running at 5us will always see this. EM806 only requires 2.5us but configuring DDCS to deliver this will risk breaking the contract woth EM806.
The Following User Says Thank You to devmonkey For This Useful Post:
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
