    Quote Originally Posted by devmonkey View Post
    after a lot of messing about I just stuck the logic in a lookup table and deleted all my code ;-)
    Hahaha love it. Sometimes 'ugly' solutions are just the best.
    My dual motor homing / squaring board is now working with the DDCS. Video clip below. DDCS was told to 'home' the X axis:
    1. Each motor stops when its respective home switch is activated,
    2. Once both home switches are activated the board signals home to the DDCS,
    3. DDCS now backs X away from home searching for switch release,
    4. If one motor's home releases before the other this motor is stopped until both home switches are released,
    5. Once both home switches are released the board clears home back the the DDCS and DDCS zero's X co-ordinate,
    6. DDC now moves X a pre-configured distance away from home.
    This logic only activates when a home switch is hit and the machine is travelling towards home. If travelling away from home either switch hit signals the DDCS (i.e. it behaves as a limit switch).
    The only downside of this is that in normal operation driving the machine past home in the X- direction requires both switches to activate before limit- is signalled. This is not a problem unless one of the switches has fallen off.
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
