14-06-2020 #10
Not sure on the debouncing bit. Sounds like you have short duration spikes of noise but would need an o'scope to check. Some sort of filtering, ferrite beads or capacitors for example might sort it out but I haven't the experience with line receivers to advise you.
We've discussed opto-couplers at length in the past (wasn't Doddy involved?) and I have been experimenting with a Long Bendy Optical Coupler (LBOC) recently but that will be for another thread.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
