    I squared the gantry today. I used the method of equalising diagonals. First I had to make a measuring stick:
Name:	IMG_20200628_114528 (Large).jpg
ID:	28479 Click image for larger version.
Name:	IMG_20200628_114714 (Large).jpg
    Then I had the machine drill 4 holes in a rectangle and inserted dowel pins, zero'd the DTI on one diagonal then measure the error on the other. The arduino board I made for axis squaring only had 8 bits of step offset. This machine uses 1610 screws and 16x microstepping so 8 bits represents 255*10/(200*16) = 0.8mm of software correction to the limit switch. Therefore I had to get it close first by moving the proximity sensor targets first, I got the diagonal error down to 0.32mm.
    Fine tuning squareness was then done by changing the offset in the arduino code. After lots of messing around trying to calculate the gantry error angle then the actual number of steps to offset one switch I gave up. I just drilled holes with offset at zero, then with offset at 255, then interpolated the two errors to get the 'correct' offset (note this is not the correct way to do this but it works well enough over these very short distances). Plugged this into the software and low and behold:
Name:	IMG_20200628_161145 (Large).jpg
    0.01mm error over ~1000mm diagonals. Square enough for now, it is repeatable. Can't do better than that without a much better DTI and some measurement of backlash.
    Annoying sources of error whilst doing this were 1) a dowel pin that got scratched up pulling it out with pliers, 2) not having the DDCS home twice, this made it a little more consistent, don't know why.
    I also noticed that the EM806 stall detection is not working for a stalled start, it works fine if you stall a spinning motor. Is this something I can tune or is it just a limitation of sensorless stall detection?
    Quote Originally Posted by devmonkey View Post
    I think that stall detection only works if the motor speed is greater than 300 rpm - so won't detect a stationary, stalled, motor. Unfortunately...
    Yep Stall detect only works above 300Rpm and yes it's limited in its accuracy and reliability.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Fair enough, it was a rather artificial scenario caused by me not plugging in the signals to one of the motors on the dual axis whilst still powering it (so the driver had it locked), the other motor stalled obviously.
    Nice job Joe. I think most of your readers would consider that 'square enough for now'
    Just in the process of rigging up some dust extraction which is going well, but I also need air assist for aluminium chip removal. I have a very loud compressor I don't want to use, can anyone point me towards something quiet that has the required flow rate and pressure (apparently some people use pond air pumps??) for blasting chips out of deep pockets?
    I've also seen these small plastic fans you can slide onto the cutter but I can't imagine they can blow chips out of deep narrow pockets.
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
