13-09-2020 #36
No Using i-machining which is Solid-Cam's version of trochoidal I can cut much more aggressively than 1000mm/min at 20mm DOC. i-machining adjusts the feed based on geometry while it's cutting and usually, it's anywhere between 2000-4000mm/min and 14-18000rpm. And that's on the medium setting 4, if I bump up the level to 7 it really rips chips, but it knocks the hell out the machine and spindle so I keep it between 3-4. This usually spits out feeds between 2-3000mm/min, 12000rpm and varies the step over between 0.1 and 0.9mm. See Pic
Email: [email protected]
Web site: www.jazzcnc.co.uk
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
