23-11-2019 #4
I found the same controller on eBay. In the description it states..
Installation and usage method:
The controller has 6 lines, the black line is the main line of the motor, the red and white are the capacitor secondary lines, the two blue lines are the speed feedback line, and the green line is the ground line.
Turn off the power, connect according to the wiring diagram and confirm that the line connection is correct, do not arbitrarily modify it;
Set the external speed knob to "0" before use to avoid transient high currents and damage the controller.
This product is controlled by generator feedback voltage, and the control line is divided into two lines: "blue" and "yellow".
When the governor is connected to the motor and found that the torque or speed does not meet the requirements, the US-52 adjusts the side trimmer potentiometer (speed setting adjustment).
To change the direction of motor operation, simply replace the jumper "CCW" and "CW" on the wiring on the back of the controller.
* When changing direction, you must change the motor after it has completely stopped running.
1) Select COM and CW short circuit, then the motor rotates clockwise;
2) Select COM and CCW to short, then the motor rotates counterclockwise.
The action switch only controls the motor to operate or stop, and does not use the power supply for interruption. If it is not used for a long time, please turn off the power.
Sprint 400i DC motor controller wiring
By Ross77 in forum Spindles & Drive MotorsReplies: 0Last Post: 16-09-2017, 09:19 PM -
Stepper Motor Wiring
By ravihotwok in forum General ElectronicsReplies: 13Last Post: 26-07-2017, 10:41 AM -
clutch motor wiring
By paulus.v in forum General DiscussionReplies: 5Last Post: 05-11-2016, 12:45 AM -
Wiring a motor - as a newbie!
By D-man in forum Stepper & Servo MotorsReplies: 22Last Post: 25-10-2014, 06:59 PM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM
