    We are selling our Mikini Mill after about 2 years of use, it is a fantastic machine with plenty of capability for a machine shop or the garage shop.
    This machine is almost identical in size to the Skyfire VMC that is now being sold. It is rare to come across one of these machines over here now. Comparable to Tormachs but these run Linear rails and high class ball screws.
    We are only selling it as we had an opportunity to upgrade to a much larger machine now we have moved into a new workshop unit and cannot justify the cost of keeping both sadly.
    Perfect for anyone who is wanting to produce accurate parts, we have made everything from custom motorcycle pieces, to jewellery, and knife making components on this.
    We have upgraded the internal lighting which is much improved, coated and sealed the tray with a 2k epoxy paint, and the machine is now running a much more capable coolant pump and sump system than the stock one it was supplied with.
    The machine also comes with around 10 R8 holders (ER, Weldon, etc)
    It is a 240v machine so will work straight off a UK supply no need for inverters or 3 phase.
    We have cut Aluminium, steel, stainless, and Titanium on this machine with no issues at all.
    The machine is very heavy for its size approx 1000kgs but is on industrial castors so can be moved around reasonably easliy and then feet lowered to level etc.
    Machine is located in Nottinghamshire NG17 - Delivery could be arranged at cost but collection preferred. Please get in touch with me if you need any further information. The machine is ready for demonstration to anyone who would like to come an view the machine.
    Price: £5500.00 as we are looking for a quick sale
    Here are some specs:
    Fully enclosed high precision 1610 series machining center
    High dynamic stiffness and class defining absolute accuracy
    Struture verified in excess of 10,000 hours of field testing
    Fits in just 3' x 5' floor space
    low silicon grey cast iron
    16 " x 10 " x 16 " XYZ travel
    30 " x 9.5 " table, 5/8" slots
    3 Hp spindle with R8 taper - Manual tool change
    310 - 5000 Spindle RPM with ISO P4 bearings
    H class linear guides on all axis
    240 AC 1 phase power
    Weight 1000kgs
    Integrated 4 axis MIKINI V2.02 CNC & Manual control system
    Instant and digitally averaged spindle load metering
    Coolant system included, installed and tested (standard)
    Manual pendant
    Fully cast stand
    Instant Manual feed rate calculation
    4 axis manual DRO
    Automated 15 point oiling system (standard)
ID:	26791   Click image for larger version.
ID:	26780   Click image for larger version.
ID:	26779   Click image for larger version.
ID:	26784   Click image for larger version.
ID:	26787   Click image for larger version.
ID:	26785   Click image for larger version.
ID:	26786   Click image for larger version.
ID:	26783   Click image for larger version.
ID:	26789   Click image for larger version.
ID:	26782   Click image for larger version.
ID:	26781   Click image for larger version.
    Chaz's Avatar
    Looks a nice little machine. I'd be interested but have 2 others and trying to buy a house. Good luck with the sale.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Mikini is the predecessor to Skyfire (IIRC same designer, but Skyfire is his own company, whereas Mikini was somebody else's company), and are good machines for what they are.
    Hey fvfdruns could I get an email for you I can’t see the photos and would like to make contact with you regards the machine.
    Regards
    Cathal
    Hi - What software does it use and most importantly post processor please?
  1. RFQ: small parts for 1/14 scale rc trucks
    By Rebekah_harper in forum Projects, Jobs & Requests
    Last Post: 16-01-2016, 10:20 PM
  2. Small footprint turning centre
    By Hellfire in forum Marketplace Discussion
    Last Post: 28-08-2013, 10:13 PM
  3. FOR SALE: Mikini 1610L CNC machining center - Mikini Mechatronics withh tooling
    By Westallc in forum Items For Sale
    Last Post: 28-08-2013, 09:05 PM
  5. BUILD LOG: Small PCB milling toy
    By irving2008 in forum DIY Router Build Logs
    Last Post: 04-10-2009, 09:44 PM
