    kell's Avatar
    Lives in doncaster, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 53.
    I have a 1.5kw 220v 400hz spindle fitted on my machine.
    All the feeds and speeds for the 1mm aluminium carbide bits are coming in at 50000rpm and up.
    Would I need a new vfd as the 60000rpm units seem to be 1,5kw
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Responded here to your other thread. Please dont open multiple threads to ask the same question.
    http://www.mycncuk.com/threads/13189...h-sub-4mm-bits
    To get 60K RPM you need 2 things.
    A spindle that can run at that speed.
    A VFD that can run at the frequency needed for 60K.
    Both are fairly expensive items.
    I have a Sunfar VFD that goes to 1000Hz, as my spindle is a 4 pole thing & hence needs 2x the normal frequency. It was a bit more expensive ($140 IIRC), but not outrageous.
    Chaz's Avatar
    That's not too bad. The spindle will be the pricy item.
    kell's Avatar
    unless i am looking at the wrong thing i can get a vfd and spindle for around £450 which i do not think is out of the park
    Chaz's Avatar
    Quote Originally Posted by kell View Post
    Fair enough. Can you link what you are looking at?
  7. The Following User Says Thank You to Chaz For This Useful Post:
  8. #7
    BTW, Jian-Ken who I got my spindle from, make a number of high speed models - and if initial tests with mine are anything to go by they're a notch above a lot of Chinese product. Time will tell of course how deep the quality goes!
  9. #8
    Chaz's Avatar
    What do they cost?
  10. #9
    Mine was about £325 landed - but it was a rather different beast to the subject of the thread, a 4 pole constant power 24K thing. Suggest you email them for a price: [email protected], the lass I dealt with was called Wafer (!). For a 1.5KW 60K spindle I think the part number is JGD80/1.5R60.
  1. How-To: Feed Rate Calculation
    By Lee Roberts in forum Machine Discussion
    Last Post: 25-03-2020, 04:09 PM
  2. Replies: 0
    Last Post: 07-08-2019, 04:09 AM
  3. Tool wear rate...
    By Davek0974 in forum Tool & Tooling Technology
    Last Post: 23-10-2016, 05:53 PM
  4. SSO/FRO (Spindle Speed/Feed Rate Override)
    By m_c in forum General Electronics
    Last Post: 17-10-2016, 11:14 PM
  5. Router bit recommendation, spindle speed and feed rate?
    By FlightCaseCo in forum Spindles & Drive Motors
    Last Post: 03-04-2012, 12:53 PM
