Thread: PC case control box
This is so annoying!
It just seems stupid that I spent all that time making the part, and then I have to make another drawing only for someone else to make another!
One last go... I messed around with settings, tried a bunch of different formats... hopefully something works.
If not I'll knock up the drawing this afternoon.
15-10-2009 #2
Hurahhh!
I think I have finally got it!
It occurred to me whilst in the shower (I find the bathroom a great place to solve problems). DXF is a 2d format, yes? For some reason when I import my Maya file into Rhino it gets rotated 90 degrees so that when you look at it from the top all you see is line! So I thought maybe I need to rotate the object so that the drawing can be seen from the top view port, and sure enough I can now see the drawing in eDrawings viewer. So fingers crossed this works.
15-10-2009 #3
Are you sure you want it 134" long ?
John S -
15-10-2009 #4
134mm...
u sure thats not to do with your import settings, or the units the prog is set to use?
15-10-2009 #5
John, you are wrong its not 134 inch's long.
Its 3.4m!
Leave it with me, I will sort it out.
Show me pics of your nicely layed out 3 drives -bob and psu 'in a case'
By nobby in forum General ElectronicsReplies: 1Last Post: 13-02-2014, 03:40 PM -
RFQ: Prototype keyboard case - CNC and laser
By Photekq in forum Projects, Jobs & RequestsReplies: 1Last Post: 26-05-2013, 08:18 PM -
Drivers,BOB and PSU are in a PC case, do i earth the case
By deannos in forum Motor Drivers & ControllersReplies: 4Last Post: 27-11-2011, 03:43 PM -
RFQ: Project Case End Plates Require Making
By flipflop in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-08-2010, 09:03 AM -
Controller box from PC case
By Smiler in forum Electronic Project BuildingReplies: 15Last Post: 24-12-2008, 03:46 AM
