    Following on from another thead it seems important to concider the way they are mounted.
    As the bearings are open then there is at least a 50% reduction in that plane, I have used 30% as a worst case. Using a quick graphical calculation it looks like the best acheivable strengh is 2/3 the stated load rating and 1/4 if mounted wrong.
    I realise that some designs are based on ease of manufacture and that if the reduced load capacity is still greater than any load generated in use then there wont be any problems.
    However if building on a budget it might be worth looking at.
Name:	Supported rail comparison 3.JPG
ID:	1667   Click image for larger version.
Name:	Supported rail comparison 2.JPG
ID:	1668   Click image for larger version.
Name:	Supported rail comparison 1.JPG
  1. WANTED: Supported rail. The bigger the better
    By r0bsk1 in forum Items Wanted
    Last Post: 08-07-2013, 07:50 PM
  2. WANTED: 2 x 20/16mm supported round rail
    By D-man in forum Items Wanted
    Last Post: 30-10-2011, 11:08 PM
  3. Profile v Supported Round Rail
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 15-09-2011, 09:29 PM
  4. Supported linear rail question.
    By IN-WondeR in forum Rails, Guideways & Bearings
    Last Post: 05-02-2010, 12:25 PM
  5. Supported rail or other?
    By lateAtNight in forum Rails, Guideways & Bearings
    Last Post: 14-11-2008, 02:28 PM
