Thread: Usb controller
    Hello , I have recently purchased a cnc 3040 4 axis router .
    The question is a daft one !!!
    If I have a controller box with a USB port ( which connects to windows 7 pc ) do I also have to install a parallel port driver ?? Or is that only to be used if the controller box doesn't have a usb port and a old style printer port instead
    Yours sincerely
    Peter Emmott
    Sent from my Nokia 7.1 using Tapatalk
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 8-9 years. Has a total post count of 475. Received thanks 104 times, giving thanks to others 43 times. Referred 1 members to the community.
    Depends....
    You shouldn't need a Parallel Port driver, but you might need a USB Parallel Port driver if that control box just has a USB to parallel port adapter inside it.
    I would guess the control box you have in based on GRBL which runs on an Ardiuno, which has a USB port built-in.
    You will need software on the PC that sends the G code to the controller, something like Universal Gcode sender, which is a free download.
    Quote Originally Posted by DaveL View Post
    Why would you assume such a thing.? . . . .Knowing these things I'd think would be much more chance that it uses Mach3.?
    So the question should be what control software are you using.?
    Pemmot.
    If your using Mach3 or 4 then you will need a Plug-in which is written exclusively for the USB controller you have.
  1. CSMIO/IP-A Controller
    By D-man in forum CS-Lab (CSMIO)
    Last Post: 07-01-2019, 09:08 PM
  2. ps3 wireless controller
    By PAULRO in forum General Computing
    Last Post: 29-12-2018, 04:10 PM
  3. Ecostep 200 Controller
    By cncland in forum Motor Drivers & Controllers
    Last Post: 14-11-2014, 07:43 PM
  4. FOR SALE: Controller Box for sale
    By lateAtNight in forum Items For Sale
    Last Post: 04-03-2012, 10:17 AM
  5. Controller Box
    By M250cnc in forum Motor Drivers & Controllers
    Last Post: 21-11-2010, 01:34 AM
