    Hi everyone,
    Could anyone recommend what sort of cable chain would be suitable for my 4 x 2 foot 3 axis router that I'm building. Just need an idea what sort of width to buy and where's the best place to buy it from.
    Regards Chris
    In my experience, wider is much easier. You can run out of room fast.
    An important consideration is bend radius. You don't want too small / tight radius as it's bad for cables (radius needs to be bigger than minimum specified for all cables you use), too big and it can be a problem fitting the cable chain. Too big is most commonly a problem on the Z axis.
  3. The Following User Says Thank You to pippin88 For This Useful Post:
    I JUST managed to squeeze everything into 15 x 30, but it did require a bit of laying in to make sure stuff wasn't crossing over anywhere.
  5. The Following User Says Thank You to Voicecoil For This Useful Post:
  6. #4
    https://www.ebay.co.uk/itm/R38-18mm-...K/163618534489
    I have this on mine. I have two on each axis to get enough room and to keep signal and power wires separate. it also makes it easier to get the cables in as it opens up along its entire length
  7. The Following User Says Thank You to johngoodrich For This Useful Post:
  8. #5
    I think the advice I found was aim to fill no more than 60% - so I measured the diameter of each cable I intended to run through, and then treated them as squares to provide a safety margin (so an 8mm air pipe takes up 64mm2). Then get the total area, and divide by 0.6. That's the approximate internal cross section you want - the over estimate on the area means you'll have plenty of room for upgrades in the future.
    Then I went shopping on eBay etc to look at common options and chose the bending radius to suit. Try to get the opening type so you can get the connectors through if you're using them.
  9. The Following User Says Thank You to AndyUK For This Useful Post:
  10. #6
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 14 Hours Ago Has been a member for 7-8 years. Has a total post count of 984. Received thanks 118 times, giving thanks to others 52 times.
    Bangood has a host of sizes available up to 25 x 77mm at minimal cost. I think I got the 15 x 40 for my machine and have all the cables inc spindle power and cooling hoses in there.
    https://www.banggood.com/buy/cable-chain.html
  11. The Following User Says Thank You to Kitwn For This Useful Post:
  12. #7
    Thanks Andy thats a good point. Maybe It would be better if I buy some CY cable and spindle cooling tubing (and whatever else I may need) to get an idea of the size of cable chain.
  13. #8
    With regards to CY cable. Is it best practice to buy shielded 2 core cable to keep step and direction signals apart in order to limit interference. Or do i use 4 core?
    Regards Chris.
  14. #9
    No problem - if it helps my four core CY cable (1.5mm2) is about the max you can use with the 2.2kW water cooled spindles before the GX20 plug becomes silly to solder on, and it's overkill in terms of the current capacity. I used it for both motors and spindle. That measured ~9mm Diameter. I used three 8mm external 5mm internal Polyurethane pipes (two water cooling and one air supply), and my limit switches use 3 core 0.5mm CY which is 7mm in diameter. The probe is the only other thing that goes through my chains, but I've taken the 0V from one of the limit switches.
  15. The Following User Says Thank You to AndyUK For This Useful Post:
  16. #10
    The CY goes between the motor and the driver, carrying the A+ A- B+ B- rather than step and direction.
    In the electronics cab between the breakout and the driver you want something like CAT5, keeping step + and - to a single twisted pair, and dir to another pair.
  17. The Following User Says Thank You to AndyUK For This Useful Post:
  1. Chain drive
    By eurikain in forum Linear & Rotary Motion
    Last Post: 15-07-2015, 01:37 PM
  2. Cable drag chain
    By birchy in forum General Electronics
    Last Post: 04-01-2014, 12:45 AM
  3. The Dragon Cable Chain
    By motoxy in forum Gantry/Router Machines & Building
    Last Post: 12-02-2012, 03:20 PM
  4. FOR SALE: Wanted: E-Chain
    By D-man in forum Items For Sale
    Last Post: 26-01-2011, 07:02 PM
  5. Plastic link chain cable carrier.
    By adscnc in forum Gantry/Router Machines & Building
    Last Post: 11-12-2009, 06:35 PM
