28-06-2021 #51
I used NPN normally closed proximity sensors in the end. I mounted them sideways on so they can't get damaged. They work a treat. I use them just as home switches. I have mounted some as limit switches but I haven't wired them up yet because soft limits seem to work just fine.
28-06-2021 #52
I'm debating my wiring for the NPN-NC prox sensors for mine too atm.
Easier to wire in series, however I have a UCBB with 18 inputs.
That's 1 for the estop, 6 for the servo, which leaves another 11 available.
Will be using CAT7 solid core shield cable to go from control box to a connector box on side of machine using RJ45 shielding connectors.
RJ45 modules at either end.
Then from connector box on machine side to the switches using flexible cable.
29-06-2021 #53
I have the CS labs IP/M controller that has plenty of inputs. I used the individual inputs rather than wiring in series.
Proximity wiring for limit switches, safety relay and a contactor
By CharlieRam in forum General ElectronicsReplies: 15Last Post: 02-06-2019, 11:18 PM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Help needed with proximity switches
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 11-07-2014, 03:29 AM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
