    Ah right, so would this be a proximity switch that could be mounted midway between say a gantry side. So its a single switch that detects a metalic reference point as it travels to the side of it at the ends of each axis. Or is there also a mechanical switch that could do this?
    I like this idea it makes a lot of sense.
    Quote Originally Posted by chillybo View Post
    You can use the same approach with simple mechanical switches but they tend to slide over a ramped trigger plate to prevent damage to switch. Or you can buy Lever type mechanical switches with end stop that flicks the lever.
    Proximity switches are my preferred switch type because they are none contact cheap and simple to use and fit.
    I will probably use proximity switches for homing and mechanical switches for limits just to add another layer of protection. Im not sure if I should buy normally open or normally closed proximity switches. My controller is the CSIO IPM and I'm using Mach 3. If I set the limit input to accept a normally closed circuit and the home / proximity switches to normally open on a different input to the controller would this work?
    Thanks in advance...
  1. Proximity wiring for limit switches, safety relay and a contactor
    By CharlieRam in forum General Electronics
    Last Post: 02-06-2019, 11:18 PM
  2. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  3. Help needed with proximity switches
    Last Post: 11-07-2014, 03:29 AM
  4. Proximity Switches
    By kingcreaky in forum General Electronics
    Last Post: 23-10-2013, 01:30 PM
  5. Proximity Sensors as Limit Switches ?
    Last Post: 03-10-2009, 07:04 PM
