So before i attempt to wire a mock home proximity switch into one of the the inputs can anyone please confirm I am understanding the wiring correctly. The brown wire from the proximity switch should be wired to positive side of the 24 PSU that supplies the IPM. The blue wire is wired to the negative side of the same PSU. The black signal wire then goes into one of the inputs on the IPM for instance pin ten. Then I designate pin 10 as the home input (X in this case) and set the pin to active low as in the picture. Is this correct? Thanks in advance
proximity switch NPN NC_compressed.pdfportnpin_compressed.pdf
Proximity wiring for limit switches, safety relay and a contactor
By CharlieRam in forum General ElectronicsReplies: 15Last Post: 02-06-2019, 11:18 PM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Help needed with proximity switches
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 11-07-2014, 03:29 AM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
