Thanks for that information Jazz. My noodle is easily fried. I used a digital calliper and let the gantry push it up against a stop on the rail. Ive unwired it all now because my control enclosure was delivered today. Im going to use the proximity sensors for homing and mechanical switches for limits. I'l position the limit switch so the gantry just touches it without switching when its detected by the proximity sensor. That way if the gantry goes to close the sensor it'l trip the limit before it damages anything.
https://www.youtube.com/watch?v=HZF8jKtbkvo
24-12-2019 #2
Your setup is not a good one.? Often when you crash into limits it's not slow like your doing in testing, it's usually at rapid feeds or higher cutting feeds when machine loses position
by missed steps due to things like Sticktion or binding, etc. In cases like these, the gantry doesn't stop instantly and you get over travel which will smash your setup to pieces.
You need to ride over switches, not into them.!
24-12-2019 #3
Point taken I'l change it when I put it back together. If what you say is a possibility of happening then how do we guard against other things getting damaged like BK / BF bearing blocks? Is it therefore wise to leave a good margin of rail / ballscrew for stopping distance?
25-12-2019 #4
Proximity wiring for limit switches, safety relay and a contactor
By CharlieRam in forum General ElectronicsReplies: 15Last Post: 02-06-2019, 11:18 PM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Help needed with proximity switches
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 11-07-2014, 03:29 AM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
