Thread: RDG Tools (Rotary tables)
Forgot to mention I got one from Arc EuroTrade
http://www.arceurotrade.co.uk/Catalo...ng-Accessories About half way down... The 4" with the stepper pre attached.
I think Kip thinks it was expensive for what it was, but at least I get to use it straight out of the box without having to design / make / wait on parts to get a stepper on it. Quality seems ok, and it weights a ton and a half.
Dave.
16-12-2009 #2
16-12-2009 #3
Only problem I had with my rotary table was fitting thrust bearings as the original just has cast iron on cast iron 'bearings'.
The backlash adjustment leaves alot to be desired and is difficult set without binding, they are not designed to be motorised so I expect will suffer from high wear in the long run.
Other fact is that they get a bit tall when a chuck is mounted on them.
peter
16-12-2009 #4
16-12-2009 #5
Personally I think you got a good deal as the conversion only costs 107.5 and that includes stepper motor and wiring to plug plus the governments cut!
See inside on this http://bbs.homeshopmachinist.net/sho...t=rotary+table post 43
Peter
DIY Rotary Encoders?
By birchy in forum Electronic Project BuildingReplies: 3Last Post: 15-09-2013, 03:09 PM -
Vacuum Tables
By Chris J in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 04-05-2012, 01:58 PM -
Bearings(Rotary)
By GeorgeD in forum Linear & Rotary MotionReplies: 7Last Post: 14-08-2010, 05:50 PM -
G & M Code Tables for Milling
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:30 AM -
Conversion Tables TO - FROM Imperial/Metric
By Lee Roberts in forum Machine DiscussionReplies: 0Last Post: 27-02-2008, 02:08 PM
