  1. Quote Originally Posted by Smiler View Post
    Cheers for that. Looks a nice table and made by Vertex too. I'll drop Mr Kip another line and enquire about the mechanicals to convert it.
    Jeff.
    Jeff,
    Did you get anywhere with this? I am now needing a rotary table to do some gear hobbing and engraving of dials for the lathe so planning to attach a stepper as well...
    Thinking of treating myself for Xmas :)
    Forgot to mention I got one from Arc EuroTrade
    http://www.arceurotrade.co.uk/Catalo...ng-Accessories About half way down... The 4" with the stepper pre attached.
    I think Kip thinks it was expensive for what it was, but at least I get to use it straight out of the box without having to design / make / wait on parts to get a stepper on it. Quality seems ok, and it weights a ton and a half.
    Dave.
  3. Quote Originally Posted by lateAtNight View Post
    Dave.
    Dave, thanks but when I said treat i didnt mean quite that much! I think i'll go for the £60 RDG one, I have a spare stepper motor that'll do the job and the mount is relatively easy...
    Only problem I had with my rotary table was fitting thrust bearings as the original just has cast iron on cast iron 'bearings'.
    The backlash adjustment leaves alot to be desired and is difficult set without binding, they are not designed to be motorised so I expect will suffer from high wear in the long run.
    Other fact is that they get a bit tall when a chuck is mounted on them.
    peter
    Haha, your not the first one to express how expensive it was :cry:. Starting to think I got ripped off.
    Personally I think you got a good deal as the conversion only costs 107.5 and that includes stepper motor and wiring to plug plus the governments cut!
    See inside on this http://bbs.homeshopmachinist.net/sho...t=rotary+table post 43
    Peter
  1. DIY Rotary Encoders?
    By birchy in forum Electronic Project Building
    Last Post: 15-09-2013, 03:09 PM
  2. Vacuum Tables
    By Chris J in forum Milling Machines, Builds & Conversions
    Last Post: 04-05-2012, 01:58 PM
  3. Bearings(Rotary)
    By GeorgeD in forum Linear & Rotary Motion
    Last Post: 14-08-2010, 05:50 PM
  4. G & M Code Tables for Milling
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:30 AM
  5. Conversion Tables TO - FROM Imperial/Metric
    By Lee Roberts in forum Machine Discussion
    Last Post: 27-02-2008, 02:08 PM
