    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    A KFlop witih a Kanalog can be made to work with resolvers, but it can be hit or miss, as it depends on how the resolvers respond, and how well they can be tuned. TomK certainly doesn't recommend it, but I am aware of at least one person who has done it, as they had nothing to lose from trying.
    However as Jonathan has mentioned, I do think I have come across an interface board for resolvers, but I can't remember any details.
    I think personally, I'd strip the 4th axis down to see if you can fit a replacement motor without having to modify the rotab itself, that way if you do sell it, you can put it back to how it was.
    A KFlop witih a Kanalog can be made to work with resolvers, but it can be hit or miss, as it depends on how the resolvers respond, and how well they can be tuned. TomK certainly doesn't recommend it, but I am aware of at least one person who has done it, as they had nothing to lose from trying..
    I couldn't see anything on the website that mentioned resolvers but didn't ask either, just took it that didn't accept them.
    Yes but it's not so easy with the way it's built. The cover is designed for round type motor with no room for Encoder and Motor wire connecters modern square type motors tend to have fitted.
    Also Iike the DC motors that are fitted I suspect the shaft size will be smaller than AC servo shafts so the coupler will need to be machined etc.
    That said I will be taking it apart to have a look.
    Lee if your reading this I can't upload Pics anymore is there a limit.? I have tried deleting some pics from old posts.?
    Most resolvers take the same excitation frequency (10kHz), but they often have different transformation ratios. If you don't have a scope to check, or know what voltage levels are required then it would end up being hit and miss.
    Quote Originally Posted by m.marino View Post
    Jonathan, you volunteering to aid in the mission of the Linux CNC side of things?
    I'll keep an eye on this thread for any questions.
    Quote Originally Posted by m_c
    That not quite what I was thinking, but is probably a better idea. I once programmed a micro-controller to convert a digital encoder (BiSS) into analogue signals to match with a motor drive that wouldn't accept much else. Going the other way round is actually easier.
    Dean, would it solve problems if you had a little board that took resolver signals and converted them to e.g. quadrature?
    If I was doing this just for my self to keep then yes I'd probably take a route something along those lines or whatever got the job done. However, this has to be done with selling the machine in mind. So I wouldn't want any bespoke boards etc which would cause a buyer hassles in the future, because the hassles will just rebound back to me.
    Saving money isn't a priority but with that said I do need to keep an eye on the budget because it can easily run away. This why industrial controllers are off the table because the machine while still very capable is still 25yrs old with a much reduced resale value and it's highly unlikely to ever see use in an industrial setting again so we cannot command the prices asked in Industry. Any new owner is most probably going to be a serious Hobby or small business user and they won't pay industry prices.
    The main priority is ending up with a Reliable machine that uses off the shelf modern components, along with a controller that works and has a decent support network that Hobby or small business person can access freely if required.
    Linux CNC/Mesa are proven with massive following and support so I've no concern in this department. Likewise so Is Kflop and Centroid and again wouldn't hesitate to use either of these.
    However, LinuxCNC/Mesa are favorites because of the budget and the fact the others offer nothing more but cost more. All of them are new to me at this level with Servo's etc so whichever there is a learning curve to deal with. But I like the challenge.!!
  1. Very Sick Lenze 534 Controller
    By Ricardoco in forum Motor Drivers & Controllers
    Last Post: 09-09-2020, 11:19 PM
  2. Replies: 3
    Last Post: 21-11-2019, 08:51 PM
  3. NEW MEMBER: Devon, UK. Fadal VMC15 10k 4 axis. Faulty VGC. Light work. Stood for 8yr.Sale/Break
    By spaaz in forum New Member Introductions
    Last Post: 21-11-2019, 03:09 PM
  4. WANTED: Live-in workshop in London
    By Eli in forum Items Wanted
    Last Post: 11-10-2014, 11:01 AM
  5. Poorly siemens inverter, wont switch on.
    By jonisonvespa in forum Spindles & Drive Motors
    Last Post: 06-12-2012, 04:45 PM
