    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 14 Hours Ago Has been a member for 8-9 years. Has a total post count of 486. Received thanks 81 times, giving thanks to others 26 times.
    That looks like a great set of components. Proper Tamagawa resolvers and closed loop (to the controller) should give decent performance! And as you say, great value for money.
    I have the 990MDCa (non absolute model, lower spec controller) that is also supplied by SZGH. However, mine came from Newker and I have to say it's been the very devil's own job trying to work out WTF their Chinglish manual was trying to say. It even got to the point where I machine translated the Chinese manual myself in desperation. Newker (and Newkye, different company) didn't seem to have anyone who could speak much better than their manuals were translated. I might have been better going with SZGH but I wasn't to know. In the end, I replaced it with an Acorn on my Shizuoka and moved the Newker onto my smaller Bridgeport machine. It's clearly quite a capable controller but has taken a lot of reverse engineering (aka trial and error) to figure out how to use some of the features. I had to rewrite the tool length offset and WCS measurement macros to get them to work on my machine and generate usable (English!) status messages.
    I'm not sure exactly how these controllers came about. Newker, Newkye and SZGH are located in completely different parts of China yet physically their 990 models look identical. Note that the firmware is subtly different, so I can tell you that mistakenly reading one company's manual while trying to program another's controller doesn't end well and they aren't prepared to support each other's products(!). I paid about £300 for my 4 axis version when I was working in China but I don't think that saved me a lot of money in the end.
    I'll be interested to see how this works out. In the meantime, I've taken a look at the 1000MDC manual and it is recognisable in general format but does at least look a bit more readable than what I was up against with the 990. However, there will still be some learning to be done while you get your head around how it is organised and what some of the Chinglish words actually mean. It's good to know you have a responsive team at SZGH - hopefully extending beyond the pre-sale period. This should be a fine machine when it's done!
    Yes I've done a lot of researching and looking around at these and all the other controllers and all the feed back relating to SZGH was mostly positive. The manual I have here is probably the best Chinese manual I've seen, I've been dealing with the Chinese a long time so I'm very fluent in Chinglish and to be fair I've got an ABB VFD manual here that is harder to read than this, mostly because it's overly technical.!! . . .There's nothing in it I don't understand in principle then I'm hoping it's just a case of feeling my way around the controller learning what's what.!
    Regards the Service then it's out standing so far. Just today they set up a direct What's App link with the engineer who is setting up and dealing with the whole project.
    He's asking me about the ATC so that is all setup and it will just be a case of tweaking timings, position parameters etc and now I've thrown the rotary 4Th axis in to the mix as well he'll be setting that up as well.
    None of this was any trouble He's offering good advise regards the Servo spindle, asking for pictures of the machine to get a feel for the conversion etc.
    I asked for the Key way to made to match the existing pully which to be fair I thought was a little skinny at 6.35mm(1/4") given the power and he's suggested unprompted not to do that because this new spindle is more powerful with higher speed so go with standard 10mm key way and I agree.
    From my dealings so far I don't think they will ignore any questions regards after sale and while I fully expect to have reasonably large learning curve and possibly the odd head bashing session I'm quite happy and reassured so far that it will work out ok... Time will tell.??
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Another small update: After further investigation of the 4th axis it seems I can remove the DC motor and replace with an absolute AC Servo to match the others, only 750W instead of 1.5Kw.
    The old motor was a round flange type and the new ones are square but it's simply case of drilling a few more holes and tapping into to the existing plate. There is a seal on the plate that motor shaft goes thru and the pinion gear clamps onto the shaft using a collet type system. SZGH are making the shaft to fit the seal and pinion.
    So when done it will back to all it's glory using the factory fitted 4th axis slimmed down with a nice shiny new controller, some extra grunt in the motors and spindle.!!! . . . . Well that's the dream anyway so lets see what reality delivers...
    Hi, did you look at the GSK controllers that are more expensive but appear to be the make that is copied by the rest of the market? It is comforting to hear SZGH are helpful.
    Quote Originally Posted by Colin Barron View Post
    Yes Colin I did. I've looked at all the main controllers from China and Taiwan and just for fun n giggles some of the well-known brands like Siemens.
    I contacted GSK directly asking questions and requesting manuals also a quote or the name of a supplier but didn't get a reply. So contacted a third party supplier who gave me a quote that was 3x the price of SZGH, couldn't answer my questions and sent me the manual for Lathe controller.!. . .
    SZGH has been fantastic so far. Virtually instant reply's (within their working hours) both with Girl who is supervising the order and the engineer. Should see it go out the door this week so hopefully not that long before lands at my door..
    I think the main thing would be to blue the shaft to check the angles on the shaft and pulley are the same (assuming the pulley is tapered). SZGH are keen for business as you say, usually same or next day for information or quotes.
    I already checked this before ordering and the pulley isn't tapered, neither is the shaft.
    I am in the process of buying a controller similar to the on you have purchased, but mine will be for a lathe and use stepper drives.
    When i asked Eileen about panel c with the MPG she said it could not be used at the same time as the hand MPG. I tried to rephrase it but got the same reply.
    Did you confirm that there was some way the hand MPG option could be used? Is it possible to buy a machine cabinet socket to connect to the panel, and plug the mpg into that socket?
    Colin
    Colin
    Hi Colin,
    My Manual says it can use Both at the same time but I've not tried it yet and it may be different for Lathe.? I've just set the controller up on the bench and I'll be posting a vid soon and then will post more as I get time.
    I'll try to find time to plug the pendant and test it for you.
    Regards the Mains Voltage on the Front panel you mentioned in your PM (sorry i forgot to reply) there isn't any mains voltage on the panel other than the 24V psu. The Start/stop buttons are not connected to anything and I will using these to control contactors etc with 24Vdc so No mains voltage will be on the panel.
    Just a quick update Vid of it on the bench for testing. If people are interested I'll post more Vids.
  1. Very Sick Lenze 534 Controller
    By Ricardoco in forum Motor Drivers & Controllers
    Last Post: 09-09-2020, 11:19 PM
  2. Replies: 3
    Last Post: 21-11-2019, 08:51 PM
  3. NEW MEMBER: Devon, UK. Fadal VMC15 10k 4 axis. Faulty VGC. Light work. Stood for 8yr.Sale/Break
    By spaaz in forum New Member Introductions
    Last Post: 21-11-2019, 03:09 PM
  4. WANTED: Live-in workshop in London
    By Eli in forum Items Wanted
    Last Post: 11-10-2014, 11:01 AM
  5. Poorly siemens inverter, wont switch on.
    By jonisonvespa in forum Spindles & Drive Motors
    Last Post: 06-12-2012, 04:45 PM
