    I have bought a used electrical enclosure but it didn't come with a mounting plate. Searching around it looks like they are usually made of steel but is there any reason I shouldn't fabricate an aluminium plate?
    Does it need to be conductive in order to provide a common ground or is it just the case that steel is used (rather than say acrylic or phenolic etc) in case of a fire within the cabinet?
    Thanks,
    The Cap'n
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Aluminium backing plate will be fine.
    Great, many thanks Clive
    I used 3mm ali in the one I inherited (thankyou Nealiboyee!) - advantages I can see include:
    greater electrical conductivity( = better earthing) than weight for weight steel
    greater thermal conductivity - used it as a heatsink for the rectifier, DC regulator/back EMF clamp, stepper drivers
    +1
    Like the idea of using it as a heatsink, I hadn't considered that.
  1. What thickness steel for mounting plate for bearings to gantry
    By Desertboy in forum Gantry/Router Machines & Building
    Last Post: 03-05-2017, 10:18 AM
  2. CNC Project - Sim Cockpit - Throttle Mounting Plate
    By Washout in forum Metalwork Project Showcase
    Last Post: 19-12-2015, 12:07 PM
  3. Material strengths for mounting plates
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 22-11-2011, 01:15 PM
  4. RFQ: Mounting Plate
    By ferus in forum Projects, Jobs & Requests
    Last Post: 26-10-2011, 02:56 AM
  5. FOR SALE: Isel-automation Flat bed X-Y table with motors and mounting plate
    By Vespa Mad in forum Items For Sale
    Last Post: 27-08-2009, 08:45 AM
