Thread: Y axis problems
20-12-2019 #1
Been a while but I've been using my machine finally and my Y axis started faulting, single motor driven.
The axis will not travel in the positive direction and makes a binding sound moves fine in the negative.
I've traced it to either a Stepper driver fault or a faulty Nema 23, checked the wiring have continuity. Mechanically everything is free no binding.
The Y axis Nema 23 is 2nd hand I have no idea how much use or age.
I've ordered 2 4nm Nema 23's to put on the X axis which will give me 2 spare 1.8nm nema's I will swap one on to the Y axis. My X axis has always been underpowered so I was planning this anyway.
I have 4 AM882 drivers one per motor.
Machine is now driven by a DDCSV I swapped the Y and Z step/dir inputs and works it's not the controller.
If it's not the Nema 23 that has failed and is the Driver can I use 3 drivers temporarily and double up the motors on the X axis driver?
If it has failed I want to swap for another AM882 which I need to get from China.Last edited by Desertboy; 20-12-2019 at 11:23 AM.
20-12-2019 #2
It's the Nema I stripped it off the machine and tried to power it directly from the driver, then tried the driver with another motor.
Driver's fine Nema is shot.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
22-12-2019 #3
It's a stepper motor, NEMA is, well, have a read -
https://www.nema.org/pages/default.aspx
:DYou think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
x,y and z axis problems on 3040T
By zxrjohn14 in forum Chinese MachinesReplies: 13Last Post: 07-03-2020, 04:20 PM -
Zeroing the Z axis has its problems !
By cncezee in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 26-04-2017, 11:12 AM -
Auto zero Z axis problems
By Jumbo in forum Probing, Digitizing & ScaningReplies: 26Last Post: 23-10-2016, 03:00 PM -
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
Boxford VMC190 Retrofit Problems, axis sounds very rough
By mikegolding in forum Boxford Vertical MillsReplies: 5Last Post: 09-06-2013, 09:11 PM
