  1. #2
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I'm assuming that the machine will run off something like a dedicated 16A 240V single-phase supply? You probably won't be using the "variable frequency" feature anyway and would leave the VFD set to 50Hz. One option is to leave the VFD running continuously, see if the device has a neutral connection on the output, and just pretend that you have a three-phase supply and everything works normally. However, you could consider something similar to the approach I took with my lathe with its 3HP/2.2KW motor. My problem was that the switchgear, contactors, etc, ran off 110V via a 415-110 internal transformer but I also wanted to use the VFD in soft-start mode, so there was no 415V available to actually start the thing. All a bit Catch-22.
    My solution was to separate out the supply to the switchgear from the motor supply. I disconnected the transformer and supplied the switchgear with 110V from an external source (actually a repurposed site transformer) and used a spare contact on the main motor contactors to switch the VFD which was permanently connected to the motor. Could you look at something similar by supplying your switchgear isolating transformer direct with 240V mains rather than from one 415V phase and neutral, and using the existing contactors (via a spare or additional contact?) to switch the VFD? This would give soft-start capability, so reducing start-up surge, as well. Even if it needs an extra 240V relay in parallel with the main motor contactors, this might be a way to do it. Mine was a bit more complicated as I needed to also run the motor in reverse, but especially because you already have a single source of power to the switchgear, it might be an easy thing to do in your machine.
  2. The Following User Says Thank You to Neale For This Useful Post:
  1. A question of Mdf?
    By Millatime16 in forum Woodwork Discussion
    Last Post: 03-12-2019, 03:17 PM
  2. NEW MEMBER: Re my question
    By oldwoodworker in forum New Member Introductions
    Last Post: 20-09-2013, 09:07 PM
  3. To usb,or not to usb,that is the question.
    By Jumbo in forum General Discussion
    Last Post: 17-10-2011, 09:21 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. A question
    By bodgeitandscarper in forum Gantry/Router Machines & Building
    Last Post: 02-12-2009, 08:30 AM
