Ah, couldn't remember of the top of my head what that was. However, I'm not sure that an incremental move up is always going to be a safe thing to do - what if the Z axis is less than 50 from its limit position? Absolute, not incremental, and machine not work coordinate move to top Z value might be safer. And making sure that right units are being used, although maybe this controller is fixed metric-only. I'm used to Mach3 where units might change and my own tool-change macro uses more code checking and setting/resetting machine parameters than it does doing the actual work involved!
1300x 1300 router with vac bed on Ebay
By Clive S in forum General DiscussionReplies: 0Last Post: 30-01-2018, 03:57 PM -
WANTED: 1300 x 900mm laser required
By discordian in forum Items WantedReplies: 1Last Post: 31-03-2017, 09:28 PM -
NEW MEMBER: Denford VMC 1300 return from the grave? (and hello from Cheltenham Hackspace)
By Chas Ixion in forum New Member IntroductionsReplies: 4Last Post: 18-12-2016, 09:57 PM -
Anyone converted a Denford VMC 1300 Pro to Mach or LinuxCNC?
By johnparker in forum Denford MillsReplies: 17Last Post: 17-05-2016, 07:24 PM -
NEW MEMBER: Manual convert with Denford VMC 1300 Pro
By johnparker in forum New Member IntroductionsReplies: 0Last Post: 11-05-2016, 06:05 PM
