Thread: Worn leadscrew?
With htd5 belt, 1:2 ratio.
13-01-2020 #2
Clearly something in the system is non-linear. Have you measured that the pitch of your ballscrew is constant along it's length?
Have you measured that DRO error in both directions? What's the Backlash?
Otherwise I don't know how it could be anything but a broken encoder or some screwy software based correction.
13-01-2020 #3
I will check if the pitch is constant.
On previous post i posted picture where i engraved ruler in both directions, no visible deviations, backlash is minimal, around 0.03mm.
14-01-2020 #4
I switched the motors, same error. I switched the drives, same error. Looks like mechanical error, worn leadscrew/nut i guess. I highly doubt mach3 would have a bug?
19-02-2020 #5
So, i have replaced ballscrew with new one, reinstalled the mach3 and the error is still there. I have no more ideas what could be wrong. Could be CSMIO IP-S motion controller faulty?
06-03-2020 #6
so i finally found the issue. One of the gantry linear rail was worn out causing z axis to swing left and right on the bottom at endmill.
06-03-2020 #7
07-03-2020 #8
07-03-2020 #9
Absolutely and very probably is due exactly to that reason. Or they are really cheap nasty rails and poorly aligned.? I've never had a rail wear out to that degree and I've probably got 100+ machines out in the field using them and many of them used 12hr 6Dwk with minimal maintenance with several over 10yr old so if quality rails like Hi-win then I'd definitely be looking for some other issue causing this.
07-03-2020 #10
Doddy: rails had 0.03mm error on 700mm
WANTED: Damaged/old/worn vmc wanted
By Westmach in forum Items WantedReplies: 1Last Post: 05-05-2018, 05:47 PM -
er32 spindle thread worn out anything i can do?
By Lloydm in forum General DiscussionReplies: 2Last Post: 01-08-2016, 10:32 PM -
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Leadscrew
By fusionkid in forum Lead Screws, Nuts & SupportsReplies: 23Last Post: 27-03-2011, 11:07 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
