Thread: Worn leadscrew?
  1. With htd5 belt, 1:2 ratio.
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 8-9 years. Has a total post count of 475. Received thanks 104 times, giving thanks to others 43 times. Referred 1 members to the community.
    Clearly something in the system is non-linear. Have you measured that the pitch of your ballscrew is constant along it's length?
    Have you measured that DRO error in both directions? What's the Backlash?
    Otherwise I don't know how it could be anything but a broken encoder or some screwy software based correction.
  3. I will check if the pitch is constant.
    On previous post i posted picture where i engraved ruler in both directions, no visible deviations, backlash is minimal, around 0.03mm.
  4. I switched the motors, same error. I switched the drives, same error. Looks like mechanical error, worn leadscrew/nut i guess. I highly doubt mach3 would have a bug?
  5. So, i have replaced ballscrew with new one, reinstalled the mach3 and the error is still there. I have no more ideas what could be wrong. Could be CSMIO IP-S motion controller faulty?
  6. so i finally found the issue. One of the gantry linear rail was worn out causing z axis to swing left and right on the bottom at endmill.
  7. #17
    Quote Originally Posted by Husky1 View Post
    Well, that's a first to me, I've never seen linear rail wear out and cause such an issue. I'll put that one in the data bank to watch out for.!
  8. #18
    If true, could this be indicative of some other underlying problem than "wear and tear"?, misaligned rails?
  9. #19
    Absolutely and very probably is due exactly to that reason. Or they are really cheap nasty rails and poorly aligned.? I've never had a rail wear out to that degree and I've probably got 100+ machines out in the field using them and many of them used 12hr 6Dwk with minimal maintenance with several over 10yr old so if quality rails like Hi-win then I'd definitely be looking for some other issue causing this.
  10. i am using 15mm tbi motion linear rails on the gantry. I have changed my setup 6 months ago, moved leadscrew too high above the linear rails. I am always pushing my machine to the limits of the spindle (3000mm/min, 2mm wall, 15mm deep, 10mm endmill). I think this was the cause to wear them. I didnt have any issue before the change.
    I am changing gantry rails now with 25mm, and putting leadscrew between the linear rails. Considering buying 6.6kw hsk63 spindle.
  1. WANTED: Damaged/old/worn vmc wanted
    By Westmach in forum Items Wanted
    Last Post: 05-05-2018, 05:47 PM
  2. er32 spindle thread worn out anything i can do?
    By Lloydm in forum General Discussion
    Last Post: 01-08-2016, 10:32 PM
  3. leadscrew conversion thoughts
    By GEOFFREY in forum Lead Screws, Nuts & Supports
    Last Post: 18-12-2012, 12:56 AM
  4. Leadscrew
    By fusionkid in forum Lead Screws, Nuts & Supports
    Last Post: 27-03-2011, 11:07 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
