Thread: Worn leadscrew?
If I remember right there are 3 rails on this Y-axis design with 2 bearings on each rail so I wouldn't expect them to wear out the rails in just over 3yrs. Even the bearings should last that long and they would wear long before the rails.? . . . But you could be right because the Z-axis is a long lever.?.
Matt which rail is worn out and how many does it use.? . . . Also how many hours does the machine have on it.? (mach3 will tell total operating time)
WANTED: Damaged/old/worn vmc wanted
By Westmach in forum Items WantedReplies: 1Last Post: 05-05-2018, 05:47 PM -
er32 spindle thread worn out anything i can do?
By Lloydm in forum General DiscussionReplies: 2Last Post: 01-08-2016, 10:32 PM -
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Leadscrew
By fusionkid in forum Lead Screws, Nuts & SupportsReplies: 23Last Post: 27-03-2011, 11:07 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
