Thread: Worn leadscrew?
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I had just assumed it was the Z-rails...
    Y the load should be spread over a larger pivot, however it'll do far more movement than the Z, so any dirt ingress/lubrication issues could wear it out quicker.
    Y the load should be spread over a larger pivot, however, it'll do far more movement than the Z, so any dirt ingress/lubrication issues could wear it out quicker.
    No, I'm pretty sure Matt had 15mm rails on the Y-axis and 20mm on X & Z. This is why I'm surprised they have worn.
    I've got a machine with 20mm Hi-win rails that I bought second-hand 15yrs ago so could be the best part of 20yrs old which have been completely utterly abused and neglected with hardly any maintenance on a machine that solely cuts Aluminium and still the rails are not excessively worn.
    It takes a lot of abuse to wear these rails and even thou 15mm I'd still expect them to last 4yrs on a machine which I'm sure isn't working in a production environment.
  1. WANTED: Damaged/old/worn vmc wanted
    By Westmach in forum Items Wanted
    Last Post: 05-05-2018, 05:47 PM
  2. er32 spindle thread worn out anything i can do?
    By Lloydm in forum General Discussion
    Last Post: 01-08-2016, 10:32 PM
  3. leadscrew conversion thoughts
    By GEOFFREY in forum Lead Screws, Nuts & Supports
    Last Post: 18-12-2012, 12:56 AM
  4. Leadscrew
    By fusionkid in forum Lead Screws, Nuts & Supports
    Last Post: 27-03-2011, 11:07 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
